VideoHelp.com Forum
  1. a real nebie question here,but when you have run throu the process with Tmpgnec and go to burn it to another disc-should it now read as an mpeg or vcd.
  2. Member bugster's Avatar
    TmpGenc produces mpeg's. A VCD is a particular way of layoing out the mpeg and some other bits of info onto a CD. Your authoring/burning program does this step for you.
  3. this might sound like a really simple question here,but how do you find the out put file that you are saving too.
  4. Member bugster's Avatar
    You are right about that!!!
    Whne setting up TmpGenc (I guess you are using the wizard) one of the dialogs should have the output filename and location. This will be filled in by default to the same filename and location as the input avi file expcept the output file will have a .mpg extension.
  5. i sure don't know what happened there with the other reply i did,but it's not mine.i'd like thank you Bugster for your response.
  1. VCD Karaoke (MPEG DAT file)- removing the vocals
    By tsrusa2002 in forum Video Conversion
    Last Post: 22nd May 2011, 02:51
  2. Can VBscript/Batch read MPEG file?
    By Cazz in forum Programming
    Last Post: 3rd Sep 2010, 07:50
  3. Replies: 2
    Last Post: 8th Aug 2010, 11:11
  4. Replies: 0
    Last Post: 27th Nov 2009, 04:40
  5. Replies: 11
    Last Post: 9th Jun 2007, 18:07
