VideoHelp.com Forum
Results 1 to 10 of 10
  1. I was just wondering if there is a way to improve the audio on an .avi file.
  2. Member unclebud's Avatar
    Improve? what does that mean.
    If you mean to,
    change Mono to Stereo? Equalize the audio? more bass?, more treble? special effects audio like reverberation? Clean up a noisy scene by removing unwanted sounds. ect., ect.
    YES, it can be done.
  3. Thats awesome, so is there any programs that could help me do this? If there is, what are they?
    thanks
  4. Sound Forge
    Cool Edit
    Goldwave
    Those are the only ones I can think of...though I am sure their are more out there.
  5. Lost Will Hay's Avatar
    If you mean to,
    How about having a little patience with the newer forum members?
    Especially the ones who try post in the correct forum?
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  6. Thanks a lot for the help
  7. Lost Will Hay's Avatar
    Good luck man.
    I'm looking to improve a low quality audio of my wedding taken with a camcorder at the back of the room, I'd be interested to learn how you get on.
    Will
  8. Member unclebud's Avatar
    JasOn, you asked if audio in a .avi file could be improved?
    Audio in pristene condition usually sounds the best (lowest signal to noise ratio). Performing other functions such as equalzation or vocal elimination often tint the remaining sound and make it sound unnatural. Less is best.
    That being said,
    Go to www.syntrillium.com and get the Cool Edit 2000 demo. It is a limited version that will allow you to use 2 of the filters/effects from start-up of the program. If you want to use other filters or effects just restart the program. Only problem is it won't load video files.
    To do that,
    You will want to get VirtualDub, linked from this site to extract the audio to a .wav file and the video to a .avi file preferably uncompressed. The file size will be large so keep the video to be altered short. Then alter the sound.
    AviEdit is a free program that will let you combine your .avi and .wav to create a new avi file.
    TMPGenc will do the same and create Mpeg 1 or 2 files of your choice.
    For best rusults,
    Sound Forge (full version) will allow you to open and alter the audio in an avi file and save it back out as an .avi file. You also will select the format of .avi as compressed, DivX (MPG4) or others.
    This might be the best way if you don't have a good NLE (Non Linear Editor) as in Vegas, Premiere, Media Studio Pro or Avid Express on thePC.
    I Hope this helps explain the process a little.
    UB
    can't really go from mono to stereo, just can go from one channel mono to two channel mono, so the sound comes out of both speakers.
  10. Member unclebud's Avatar
    Yea, I meant stereo to mono.
  1. How to improve muffled audio
    By dexter30 in forum Audio
    Last Post: 24th Dec 2009, 11:17
  2. Choppy .avi is there a way to improve it?
    By dexter30 in forum Restoration
    Last Post: 13th Sep 2009, 10:12
  3. Replies: 8
    Last Post: 20th Sep 2008, 12:14
  4. question about demagnetizing audio head on VCR to improve audio
    By jimdagys in forum Newbie / General discussions
    Last Post: 29th Aug 2008, 16:47
  5. desperate to improve my home movie
    By timster123 in forum Restoration
    Last Post: 15th May 2007, 07:06
