Hi everyone,
I would like to capture some Art demos and intros for making background menu movies for my DVD creations...
The most comfortable way would be to set one firewire port to sending out the current vga signal and the other (got one on motherboard, one on audigy) set to 'capture' in scenalyzer for example.
Is that possible in any way? Is there any tool out there that makes this possible?
I would have another machine as well, so I could 'capture' there if out+in on same machine doesnt work.
Additionally I got a DVPro machine that could convert my S-video out signal into DV-Firewire which I could capture the same time I 'send' out the vga signal on the same machine .. (if the demos/intros dont use too much system resources.. else I would use the other machine).
And the last option is to capture the s-video In signal on the other machine I give out on the demo/intro machine...
But the best way would be the first option where I dont know if that works at all. Would give the best quality of course.
If you know any possibility to do that, I would like to get some help
[idea again: VGA signal > Firewire out > Other Firewire in (capture)]
thanx
If the source is a DVD just use screen capture in the software DVD player.
Your post is a bit confusing as it is not clear what you are capturing from.
VGA signals don't travel over DV but video does.
SOme people have used a video card with SVideo/RCA/Scart (Europe) out to a capture card for complex stuff. There is also screen capture programs that do a good job on fast computers. That might be your best bet.Panasonic DMR-ES45VS, keep those discs a burnin'
hi
thanx for reply.
sorry about my english, i'm swiss
well, in easy words: I want my firewire port working like my S-Video Out port on my VGA Card ...
To activate it (give vga signal out to s-video) you just enable it in the graphic properties.
So the question is, if there is any possibility to send out the 'what-you-see' vga signal out through firewire (as digital video).
All i want is to capture what I see, at 25fps.
That Camtasia Snapshot stuff is useless.
CPU upgrade possibility
By zzyzzx in forum ComputerReplies: 10Last Post: 2nd Feb 2011, 18:12 -
Send DV through Firewire to a DVD recorder
By nlec in forum ProgrammingReplies: 16Last Post: 2nd Oct 2010, 02:56 -
Is this a possibility or not?
By rocknroller in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Jul 2009, 13:24 -
Why won't MiniDV camcorder pass signal through to external firewire drive?
By KeepItSimple in forum MacReplies: 12Last Post: 24th Oct 2008, 07:49 -
Laptop vga out to LCD tv (not a "no signal" problem)
By Keystr0ke in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 11:15
Statistics
Newest guides
Latest tool updates
New media comments
