VideoHelp.com Forum
    I use Nero's DVD-Video option which makes DVD-R's that play in my standalone player. But the discs don't play in all standalone players. Is there a particular format that will play in all players? I am referring to players in just one zone.
    Yes (that is assuming the player can play DVD-R's in the first place.) Check out this link...
    http://www.dvdrhelp.com/forum/viewtopic.php?t=127624
    Thanks. Does using UDF 1.02 produce backups that will play in any zone?
  4. Член BJ_M's Avatar
    UDF 1.02 has nothing to do with what zone any dvd is ..
    if you specifically dont do a zone on authoring .. the disk is zone free .
    What file represents the zone?
  6. I'm a bit of a newbie to all this, but I've found that discs burned in UDF1.02 format will NOT play in my Pioneer Elite DV-09 standalone. Using nero's 'DVD Video' template (which I believe is UDF1.05) works brilliantly. Both UDF play in my cheaper Pioneer standalone.
  7. The region encoding is added by commercial disc producers into the encoding. If you are doing your own material don't worry as there will be no region encoding and it will play anywhere (although you have to think about PAL vs. NTSC).
    Panasonic DMR-ES45VS, keep those discs a burnin'
  1. Universal Video format for streaming
    By musomn in forum Video Streaming
    Last Post: 30th Apr 2011, 03:34
  2. Most universal format for PC's
    By skinnyneo in forum Newbie / General discussions
    Last Post: 24th Mar 2010, 17:20
  3. 3gp to most universal format
    By rokeeffe in forum Video Conversion
    Last Post: 6th Feb 2010, 15:12
  4. Universal encoding for random format videos ??
    By lostnucleus in forum ffmpegX general discussion
    Last Post: 19th Oct 2009, 08:33
  5. Best (smallest) format for movie burning
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 1st Oct 2007, 09:38
