How do i convert avi to avi but the converted avi should be small and if neccecary in more bad quality ? And with which program?
check the "tools" section, and look for Stoik Video Convertor.
It will allow you to resize an .avi, or use a different codec and re-encode an .avi (I wasn't sure which "smaller" - file size or image size - you meant)
It's decent quality, and pretty fast - lots of the stuff I've used it for (reencoding from .wmv to .avi, or changing from uncompressed .avi to Divx .avi) it runs close to or faster than realtime (30 fps).
Another option that will give you more control (and is a much more robust program overall) is Virtualdub - it's great. It's a little harder to use than Stoik Video Convertor at first, but only because it's got so many more features than SVC.
hope this helps. good luck.
- housepig
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 11:01 -
Convert Digital Camera avi's to smaller size
By nook in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2008, 06:13 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 10:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
Statistics
Newest guides
Latest tool updates
New media comments
