I am attempting to re-encode a DVD that is roughly 7gig to fit a 4.5gig DVD-R. I am using ffmpegX. I keep getting the same error when setting it up.
I use the "low-bitrate DVD (NTSC)" setting and I keep getting the following error:
I am left with a file with .mp2 appended to it, even though I have chosen .ac3 as the Audio format. It loks like the video is failing completely and it goes on to the audio. I used DVD Backup to extract the DVD and am using the VOBs it extracted.pbpaste | sh
Encoding started on Thu Feb 27 20:37:23 CST 2003
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP42/MSFT)
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 4294967256 bytes
INFO: slots/frame = 384
INFO: frac SpF=0.000, tot bitrate=128 kbps, s freq=48.0 kHz
INFO: System is big endian
^C972 frames in 490.73 sec (50.89 fps), 30 last 0.61 sec (49.18 fps)
25003 frames decoded in 491.01 seconds (50.92 fps)
Any ideas?
Flaffer
You're probably encoding with "QT decode" option set, and without having installed the Quicktime mpeg-2 player component, which is required for this option to work with mpeg-2 input.
Major writes:
I see. I saw that being checked but had no idea what it was so I left it. What does having the QT mpeg-2 component buy me? Or is it best to just uncheck it?You're probably encoding with "QT decode" option set, and without having installed the Quicktime mpeg-2 player component, which is required for this option to work with mpeg-2 input.
Thanks for the info,
Flaffer
If you're encoding PAL material you probably don't need "QT decode" enabled. If you're encoding NTSC, you could need either "mplayer decode" or "QT decode" to keep sound sync, and "QT decode" is faster.
Error message - Could'nt read YUV4MPEG header
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 29th May 2010, 00:56 -
Error on ffmpegX
By affonsohnunes in forum ffmpegX general discussionReplies: 9Last Post: 15th Jan 2010, 08:21 -
DIV16B_KEY what does this error mean at ffmpegX
By joachino in forum ffmpegX bugs and suggestionsReplies: 1Last Post: 12th Feb 2009, 09:33 -
Ripping Error: Pack Header Not Found (0x00000000)
By src2206 in forum DVD RippingReplies: 6Last Post: 26th May 2008, 11:49 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
