VideoHelp.com Forum
  1. I just got one of these and read the whole book thru... i got all the editing down and i can get it to copy from tv to dvd.... but when i record something on to the hard drive and then try to copy it to dvd it says something about disk not compatible or cant copy to disk..... it even does it to the dvd ram tht comes with it... can anyone help me with this??????
  2. sounds like you need to format the disc. It is in the main menu where you input title.
  3. u cant format the disk till (suposley) after u burn the dvd.... also like i said if i hook up a live feed from tv or utv to the box it wll burn to dvd then.... it just dont burn from the hard drive
  4. ..... BUMP...... CAN I PLEASE GET SOME HELP...... TAKIN YALL A WHILE
  5. You should not have to format a DVD-R in order to dub material from the HDD to DVD. Are you sure you are using a DVD-R, not DVD+R, DVD-RW, or DVD+RW. Those media will not work, hence the "incompatible media" message.
  6. it works now.... unpluged it for about two days and for some reason its no problem workin
  1. Panasonic DMR-HS2 power on failure
    By rmhartman in forum DVD & Blu-ray Recorders
    Last Post: 3rd Feb 2012, 14:19
  2. Panasonic DMR HS2 (Setup Mode?)
    By philo in forum DVD & Blu-ray Recorders
    Last Post: 4th Jun 2009, 12:14
  3. Panasonic DMR-HS2 - shuts down when I try to record
    By donmeyer2 in forum DVD & Blu-ray Recorders
    Last Post: 4th Sep 2008, 22:35
  4. Problem with Panasonic DMR-HS2
    Last Post: 20th Feb 2008, 15:07
  5. Replies: 6
    Last Post: 13th Sep 2007, 02:12
