VideoHelp.com Forum
    Hi everyone.
    I'm trying to get my home video onto a dvd to send to relatives. I have my video captured, and even edited the way I want it (from MS Movie Maker), but I'm stuck after that. I can get CCE to encode it, but I don't get any sound. CCE crashes when I try to separate out the sound file too.
    Are there any guides around that describe taking digital camcorder stuff and putting it on a DVD?
    Any help would be appreciated... I'm totally stumped...
  2. I am assuming you are using CCE multipass VBR to encode to MPEG2 since you are trying to make a DVD.
    When you do this, CCE splits the video and the sound creating an .mpv and .mva files respectively. These 2 files need to be multiplexed together to create the .mpg file. This can be done using TMPEG multiplex mpeg tool (simple multiplex, MPEG2 program stream).
    Once this is done, I create the DVD menu & burn on DVD using DVD workshop.
    Also, since you are talking about home video, I am assuming the source is coming from a camcorder so do not forget to check the field order before encoding as you might need to invert it.
    Let me know if this helps
  3. Have you tried a type 2 DV avi file? You can capture type 2 DV avi files with DVapp or DVIO. You also need to install a DV codec such as the Panasonic DV codec.
    Do you have the same problem with TMPGEnc?
  4. Hi
    Get a copy of Pinnacle Studio 8, it allows you to complete the project from capture to burn, including some great FX transistions and DVD motion menu's
  5. Studion 8 is fine for editing, adding transitions, etc... but mpeg encoding quality is poor.
    For guidance on DV -> SVCD check the usefull link section, they recommand the following link:
    www.dvideohome.com
  1. AVCHD Disc (DVD) from Camcorder Home Movies
    By Xesdeeni in forum Authoring (Blu-ray)
    Last Post: 22nd Jun 2011, 10:05
  2. Toshiba RD-XV48DTKB - Recording NTSC Camcorder Home Video
    By Bigby in forum DVD & Blu-ray Recorders
    Last Post: 27th Sep 2009, 18:10
  3. Analog Camcorder to Digital Camcorder Cable Question
    By bradnwa in forum Newbie / General discussions
    Last Post: 12th Jun 2008, 12:47
  4. Replies: 6
    Last Post: 3rd Jun 2008, 11:36
  5. Record 8mm Home Movies w/Digital Camcorder?
    By stahlhart in forum Newbie / General discussions
    Last Post: 28th May 2007, 15:28
