VideoHelp.com Forum
  1. I didn't know where I should post this. I have been reading the forums for a couple months now and haven't seen the answer to this question or in fact this question being asked. I have read through the how-to guides and still can't find anything about it. I use VirtualDub to convert the audio to WAV format, then use TMPGE for the conversion. My question is how can I keep the picture from being so dark after the conversion (MPEG1). I use the standard NTSC setting. I am fairly new to converting Divx to MPEG to view on a standalone DVD player. I don't know a lot about the settings to be making changes to them.
    Tmpgenc does not change the brightness of the video when converting. The original file is most likely dark, but you change the brightness in Tmpgenc when encoding. Also, a PC monitor is often a poor way of telling if the video has the correct brightness and contrast levels. Play the file on a TV set that has been adjusted correctly for color bars.
  3. Thanks. I'll check it out once it finishes encoding. When I preview it in TMPGE it looks so much darker than it did when I played it in Divx Player. I will wait and see what the outcome is.
  4. the true test is on the television. i recorded a live band in a room where the lighting was very dim. watching it through my camera looked fine because i had the brightness turned up on the LCD. after dropping it to the computer, it looked extremely dark. i converted it to MPG2 and burned it to DVD and the video was not as dark as i thought. just like tv adds some pounds to you, computer monitors add a lot of darkness.
  5. Thanks for the answers. I didn't even think about it like that.
  1. Replies: 0
    Last Post: 17th Nov 2010, 05:32
  2. Replies: 11
    Last Post: 2nd May 2009, 21:39
  3. HDV Picture is too dark.
    By dj_magic in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Jun 2008, 14:21
  4. How to improve dark VHS picture?
    By rbatty11 in forum Restoration
    Last Post: 11th Sep 2007, 18:57
  5. Dark picture
    By MarioB in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Aug 2007, 23:14
