VideoHelp.com Forum
    Appologies if this has been asked before? I tried searching.
    As I understand it when a VCD format mpg is burned a header is added?
    So here goes, without re-encoding, How can I remove the header and return to a compliant VCD format mpg quickly as I tried simply renaming them and they didn't work to put on a dvd whereas I can easily and speedily put vcd format mpgs onto a dvd that play as dvd in my players. IE smoother ff/rev and fwd & rev slo-mo. It takes a while as it transcodes the audio etc. but much quicker than tmpgenc'ing would be to convert to dvd format.
    Thanks in advance
  2. All you should have to do is convert the audio to 48000 instead of 44100. That is what i have been doing and it works great when burning it to dvd no reincoding or transcoding at all. I simply use tmpgenc to strip put the audio and convert it to 48000 and then remultiplex the video with the audio and the results are zero quality loss when burning them on to dvd. hope this helps.
    Ok, Thanks a lot!
  1. can you edit the header of an mpg file
    By lmwashere in forum Editing
    Last Post: 13th Nov 2009, 21:07
  2. Phillips 5990 - How to revert back to original firmware
    By user111 in forum DVD & Blu-ray Players
    Last Post: 11th Feb 2009, 19:31
  3. How to revert back from .wmv to .avi with correct ratio of 4:3?
    By tigerb in forum Newbie / General discussions
    Last Post: 13th Nov 2008, 01:09
  4. Remove Vocals from a cd/mpg
    By Harmetheous in forum Audio
    Last Post: 18th Feb 2008, 16:14
  5. How do i revert back to HD?
    By meneverlearn in forum Newbie / General discussions
    Last Post: 7th Jun 2007, 09:06
