hi, pls help me,
1. how do u open/save mpeg2 files with virtualdub ? which codec should i buy.
2. my tv system is PAL-B, so when i capture with virtualdub some part is clipped. how do i set the tv system in virtual dub?
3. which i the best software for video capture realtime mpeg2 or avi, the one that will automatically split captured avi files to be less than 4gb (in case of avi).
thanks in advance.
Thread: Vdub and capturing
ok see, Vdub doesnt capture nor save any file on MPEG stream.. If you want to get a MPEG file put of it then do the following...
Open up Vdub, and then goto (Video -> source) and select your tv system, once that is done, goto (video -> compression) and make sure you installed "Huffy Codec", if you did it will appear on the list. Now you choose that and click on ok, then goto (video -> set format) and choose your video resolution you would like to capture,.. NOTE: if your running under a 1.4 CPU i siggest not going higher then 352*240...there are options there but there are few..if you want custome resolution then goto (video -> set custom format) and choose your format there.. now i suggest you use YUV2 instead of RGB, those options will appear right under or besode where you chose your resolotion.. Once that is all done you just press F6 and it will capture the video in (C:\capture.avi)..
Ok before you do anything of what I mentioned above, the first thing you need to do is open vdud and goto (file -> capture AVI) and then goto (video -> and choose preview)... then you do what i mentiojned above and then you can press F6 and you got yourself a AVI, then what you will want to do is close Vdub, then open it again and goto (file - Open video file) and you would choose your capture.avi file and click on (audio -> and choose no audio) and then you would goto (video -> and choose your huffy again, then you would goto (file -> and click on save avi) and you would save the avi as a video source only.... once that is done (aprx 10-20 min) you would close vdub and open it again and open video file again and this time you would just goto (file -> save wav) and you would choose a destination to choose your wav and itll save it..wont take that long.....
After that its simple.... open up tmpgenc (mpeg1/2) encoder and you would load the video file and then the audio file and you would goto settings and choose if you want it to be a svcd or vcd, then you encode and you got yourself a VCD/SVCD>..... HOPE I HELPED???
CIAO
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum CapturingReplies: 0Last Post: 10th Jan 2012, 19:06 -
Problems capturing HDMI with AVerTV CaptureHD/-H727 and VDub
By Gwar in forum CapturingReplies: 5Last Post: 12th Sep 2011, 19:00 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 8th Feb 2010, 20:50 -
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 10:39 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 06:40
Statistics
Newest guides
Latest tool updates
New media comments
