Hello Guys,
I try to compress a DVD with Gordian Knot 0.27. I compressed before with 0.26 and I know the procedure. My problem is: When I do the Compressibility check either doesn't do anything and just says Check Finished or does the Compressibility check but does not load the values in Gordian Knot. Any ideea ?? I installed Gordian Knot 0.26 but same problem. Also I tried with both DIVx 5.02 and 5.03 Pro.
Thanks !![]()
when it does not load the values,its because divx 5.03 doesn't work well with Gordian Knot.its not updated to work with 5.03.
unistall 5.03 and delete the divx folder then install divx 5.02 pro.
Thanks man. It worked. I don't understand though, because when I first installed Gordian Knot, I tried with DivX Pro 5.02, then BECAUSE it did not worked I've downloaded 5.03. Must've done something else wrong at that time.
Anyway, Thanks.
VCDHelp and it's members rule !
8) 8) 8) 8) 8) 8)
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Problem with Gordian Knot
By eliqush in forum Video ConversionReplies: 3Last Post: 7th Jul 2009, 19:35 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
Problem On Encoding DVD to H.264 By Gordian Knot
By bugsboney in forum Video ConversionReplies: 6Last Post: 27th Jul 2008, 09:52 -
Gordian knot sound problem !!
By markos in forum DVD RippingReplies: 3Last Post: 22nd Nov 2007, 03:58
Statistics
Newest guides
Latest tool updates
New media comments
