VideoHelp.com Forum
Results 1 to 12 of 12
  1. This may sound simple but how do you download movie trailers. When I click on the link it will play over the internet (windows media player) but how do I save it.
  2. Hi m8,
    i would reccomend using a download manager such as Download Accelerator Plus (get from www.download.com and search for it). if you set it as your default download manager it will, not only allow you to resume broken downloads, it SHOULD mean that just clicking on the link will enable you to download it. if this DOESNL;T work and it still plays in windows media player then if you right click on the link there should be an option to download with download accelerator.
    hope this helps buddy!
    What has this to do with capturing???
    Fozz
  4. i have the same problem but the solution of freak in cage do not work...
    when you try to reach the link of the video file on the net... you will not find the entire file but just a link in wmv format.... and the link for the real file is encoded in it..... if somebody know the solution ... tell me to
    If the link is in wmv format that is what the file is.
    A windows movie video!! e.g. Star Trek.wmv .
    What do you mean the link to the REAL file??
    Trailers you can't save are only meant to be viewed.
    Fozzee
  6. Instead click the link, click the right in mouse and click on "save target as"
    hope this help you
    lots of websites let you download trailers. just go to google.com and search for trailers download'
    or you can get a program like asf recorder that will copy streams. usually the streamingfiles give a link to an asm file but then at then end of the link it will say something like url=http:\\.......... that is the real file . copy that part of the link and then you can download the real file
    I've noticed too that most trailers now are streamed files.
    However have you tried:
    http://www.trailersworld.com?
    They usually have the most popular trailers as the full downloadable file e.g Terminator 3.
    If they don't have it, a quick search using google in the following format
    "Film Name"+trailer+download
    will usually find you the complete trailer, by people far more accomplished than I, who have solved this.
  9. Originally Posted by secretagent
    is that a way to save this streaming file (after i downloaded it with asf recorder) as a mov or mpeg file?
    once you have the saved asf file you can convert it to mpeg with Tmpgenc
    or open it in some versions of vitrual dub 1.4c or something like that
  11. does anyone know any other good trailer page to download trailers to hd?
    i'm crazy after "gone in sixty seconds" trailer, i can only find the little one, i would really appreciate at least the medium one.
    anyone?
  12. use quicktime pro and visit the quicktime movie trailers site
    save any trailer you want then convert to mpeg with tmpgenc
  1. Movie Trailers?
    By xxnonamexx in forum Editing
    Last Post: 5th Nov 2011, 14:02
  2. Movie Trailers in Quicktime
    By skorpinok in forum Newbie / General discussions
    Last Post: 25th Aug 2010, 11:39
  3. No signal between movie trailers - Blu-ray
    By irongamer in forum DVD & Blu-ray Players
    Last Post: 3rd Apr 2010, 23:54
  4. Apple.com disabled downloading trailers..
    By GINTER in forum Video Streaming
    Last Post: 25th Jan 2010, 16:58
  5. Which is the best method to add video (movie trailers) to your website?
    By r00kie in forum Newbie / General discussions
    Last Post: 2nd Aug 2007, 12:19
