I hope someone can help me with this. I made a dvd image over a year ago of a dvd I had. The dvd since then has become damaged and can't be played any more. I have tried to use 42 to downsample the mpeg2 file because it was about 4.9 gigs. What I get is a 3.5 gig .mpg file and a 3.0 m2v file that I have not had any luck turning into a burnable video_ts folder. I tried sizzle but it needed a separate audio file in addition to the .m2v file. I also tried several tools to try to extract the audio from the .mpg file but they either crash on me part way through or spit out a bunch of smaller files that I can't figure out how to join to make one file. Also I found out that 42 had turned the audio part into a .mp3 file. Ideally, I wanted the .ac3 audio file.
It would be so easy to use OSEX to extract the audio from the image if it could work with images. Does anybody know any way that I can get the .ac3 file from the image and use it to author the video_ts folder? I could also settle for the .mp3 file if I could find a reliable way to extract it from the .mpg file. Any ideas??
Thread: Ripping help!
if your original dvd doesn't works cause it's scratched... there's a way to recover it. use a soft piece of cloth, like those things you use to clean the windshield (parabrisas) of your car. then you must add some metal polisher, just a couple of drops and then clean the surface with this for a while with some strenght. this will remove the damaged layer of your dvd and will play as nice as before.
After doing that, you need to use another piece of sotf cloth to wipe the rests of the metal polisher and that's it.
I usually do this with my playstation discs, music cd's... dvd's not yet cause i take good care of them... too expensive to be careless about.
Hope this may recover your dvd. at least this process works for me and a lot of people here.dj_yerba says: legalize it!
VIVA CHILE MIERDA!
Help with ripping
By kuasd in forum Video ConversionReplies: 5Last Post: 26th Oct 2011, 07:57 -
Ripping with Im Too
By rocks911 in forum Blu-ray RippingReplies: 3Last Post: 5th Oct 2011, 18:57 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22
Statistics
Newest guides
Latest tool updates
New media comments
