VideoHelp.com Forum
  1. hi ca some one advise me as i am having probs and they are ,when i try to open non mpg files ie ,avi i get an error warning under the heading
    ACTIVE MOVIE :WM PLAYER.EXE UNABLE TO LOCATE COMPONENTS
    in this window it says this application has failed because MSVCR70 DLL
    was not found i am using win xp pro with tmpeg ,nimo codacs and dvix5 what is my prob and what is the best for converting avi movies as it is getting confusing with all the different down load programs and codacs ?
    thanks [/b]
    wing nut
  2. Member unclebud's Avatar
    Sounds like you have a dud (fake) video.
    Try G-spot available from the tools section on this site. It will give you information about the video file such as whether it has an audio track or a vilid video track. Check it out.
  1. Replies: 1
    Last Post: 15th Feb 2011, 08:34
  2. How to tell active codec?
    By The111 in forum Newbie / General discussions
    Last Post: 2nd Nov 2009, 06:19
  3. Active Buttons on DVD Menu
    By dartmanx in forum Authoring (DVD)
    Last Post: 22nd Jun 2009, 04:53
  4. Replies: 1
    Last Post: 31st Dec 2008, 16:25
  5. Automatically open WinDV when DV device becomes active
    By jabloomf1230 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 9th Jun 2007, 22:30
