I don't need anything with fancy transitions or effects. Just something basic that will cut precisely on my marks. Tried Vdub, but it is unreliable in this respect, always adding extra frames or lopping them off, but rarely cutting on the marks I set.
Vdub makes cuts at "key" frames. If you try to cut between at the start of your clip, it will move to the next previous. Key frames are important for maintaining A/V sync when playing the file. I believe you can cut in between if it is the end of the clip but you need to start the clip with a key frame. Not sure if you can rederive a new key frame at the point you select, maybe someone else might know.
catching up...Can you recommend a good camcorder?
By gts101 in forum Newbie / General discussionsReplies: 9Last Post: 16th Nov 2010, 03:44 -
Can anyone recommend a good AVI editor?
By djdust in forum Newbie / General discussionsReplies: 48Last Post: 17th May 2010, 13:46 -
Recommend a good subtitler?
By Djard in forum SubtitleReplies: 6Last Post: 9th Nov 2009, 02:57 -
Can Anyone Recommend a Good Audio and Video Tag Editor?
By Nitro89 in forum ComputerReplies: 1Last Post: 23rd May 2008, 02:16 -
Is there a good tag editor like MetaX, except able to do AVI and MOV files?
By VidHunter in forum MacReplies: 0Last Post: 9th Nov 2007, 05:57
Statistics
Newest guides
Latest tool updates
New media comments
