hi i need to record avi movies from my pc to vcr can u tell me which card to use and also which software i can use to make these avi movies a bit more brighter turn up sound etc thanks alot
Thread: pc to vcr for recording
first connect tv out to tv and adjust overlay controls and range to fit ur picture to the screen.
since u r using a vcr u can re record again and again to get the perfect setting.
a picture that may look dark on ur pc will look brighter on ur tv.
thanks but waht i need to know is what is the cheapest card to buy , i cant ouuput as yet what i normally do i s i make vcd from my avi files but that take years and the quality is mostly bad.
so i wanted to know of any tv card that i can use to output avi files to my vcr thanks
you could get a cheap 64mb Geforce4 card w/ a tv out on it. If you have an AGP slot you could pick one up for about $60 or a little more for a pci version.
recording test pattern on a vcr from PC
By mammo1789 in forum CapturingReplies: 11Last Post: 13th Apr 2012, 09:59 -
Need LG897T dummy instructions on VCR recording
By Astrovel in forum DVD & Blu-ray RecordersReplies: 5Last Post: 6th Mar 2009, 23:45 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 26th Oct 2008, 18:23 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 17:45 -
What is the exact physical point where recording happens vcr and a tape ?
By arturock in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2008, 21:15
Statistics
Newest guides
Latest tool updates
New media comments
