VideoHelp.com Forum
  1. My question is that TMPGEnc uses "3:2 pulldown on playback" while the Pulldown.exe app uses "2:3 pulldown on playback". Do these options produce the same results or does one repeat a field in the even frames while the other repeats a field in the odd frames? If a movie was encoded with TMPGEnc using the 3:2 pulldown on playback, is it ok to use pulldown.exe to switch all the flags to 2:3 pulldown on playback?
    Also, I did see the post at http://www.dvdrhelp.com/forum/viewtopic.php?t=125455 on this topic but I'm still confused. What does the 2:3 pulldown in the pulldown.exe app actually do?
    -Dan
    3:2 pulldown when playback is used when you have a FILM source movie (23.976fps) to leave it 23.976 but have your decoder play it back at 29.976fps (works great for ripping DVDs). When 3:2 pulldown is used it does this.. It takes four sequential video frames (A, B, C, D) from the FILM and are drawn on the video display as A1, A2, B1, B2, C1, C2, D1, D2, where the 1 or 2 represents the field number within the frame.
    Hope That Helps!!! :P
  3. Member adam's Avatar
    I think both flags do the same thing. I don't know why TMPGenc calls it 3:2 pulldown, everything I read elsewhere speaks of 2:3 pulldown. Like puertorican said, the flag instructs your dvd player to repeat fields in a 2:3 pattern, so that the framerate is increased to 29.97fps during playback. The idea is encode at 23.976fps but still have it play back at 29.97fps, which is the required playback speed for NTSC. This saves you about %20 more bitrate because you now have %20 less frames to encode.
    Is TMPGenc in fact duplicating different fields as compared to pulldown.exe? I doubt it, but even if so it doesn't really matter. The whole point of telecining is that you don't notice the extra fields, so when its actually played it might as well be the same, and in all liklihood probably is.
    If you use one or the other than your fine. If you are worried about TMPGenc doing it incorrectly pulldown.exe can remove the flags and then add its own, but you will have to run it through twice. Or you could just turn off the 3:2 pulldown flag option in TMPGenc and use pulldown.exe instead.
  4. adam, puertorican138,
    Thanks for the replies. I think I understand it.
    -Dan
    -Dan
    Anytime! :hahaha:
  1. 2:4 Pulldown
    By supervehicle in forum Video Conversion
    Last Post: 3rd May 2011, 16:53
  2. playback with no pulldown on a dynex 60hz lcdtv
    By octeuron in forum Newbie / General discussions
    Last Post: 5th May 2010, 10:05
  3. major difference in playback quality between vlc and wmp
    Last Post: 26th Feb 2010, 17:05
  4. 3:2 pulldown?
    By blizzery in forum Video Conversion
    Last Post: 24th Jul 2007, 06:38
  5. Using pulldown
    By MysticE in forum Video Conversion
    Last Post: 14th Jul 2007, 03:25
