VideoHelp.com Forum
  1. I Have a Leadtek winfast 200xp and a hercules 3d prophet 8500le. I want to be able to record from my computer to vhs how would i do this?
  2. I have a graphics card with t.v out which works perfect, top picture, I just hook up an s/video lead with an s/video scart converter to my video, from my g/card. and it records any, avi, dvd, mpeg.................ect.
    SATAN
  3. Member rhegedus's Avatar
    OK - this is what you need.
    1 VCR
    2 portable TV
    3 s-video cable
    4 line-in to line in cable
    tune in the TV to the VCR and connect the s-video and line-in cables from the graphics card to your VCR (you'll probably need a scart adapter to do this)
    enable the two display mode of the graphics card (somewhere on the taskbar you'll find the ATI icon - right click and then go to the monitors section and chose to output to monitor 2 - your PC monitor will change resolution and piss about a bit. If not, change resolution to something very low, otherwise the output to the TV will not fill the screen properly.
    now find the computer signal on the VCR (if you're using a scart it will be one of the EXTensions)
    adjust the monitor dimensions at the ATI icon so that the image of your desktop fills the portable TV nicely. Don't expect much clarity, portable TV's aren't meant to be used with PCs.
    once you've got the signals sussed then you're ready to record, but when you do, be sure to move the mouse off screen first (otherwise it will record the mouse cursor too!)
    Regards,
    Rob
    These Connections sound great, but what about sound? I'm unfamiliar with an S-video connection and thought its meant only for video. Not for both audio and video like an coaxial cable. I thought with S-video, you'd have to run an Y-splitter with RCA jacks out of the sound card to the VCR to get sound as well. Would appreciate an reply to let me know if you can get both audio and video with an S-video connection out of the video card to the recorder.
  5. Member rhegedus's Avatar
    That's what you use the line-in to line-in cable for.
    Regards,
    Rob
  1. Standalone recorder that doesn't stop recording in response to VHS snow?
    By thx1138d2002 in forum DVD & Blu-ray Recorders
    Last Post: 2nd Dec 2011, 22:55
  2. Need a DVD Recorder Or better VCR for Recording VHS to DVD
    By Konfusion in forum DVD & Blu-ray Recorders
    Last Post: 8th Apr 2010, 23:09
  3. DVD-VHS Recorder Proplem with Recording
    By mactek in forum DVD & Blu-ray Players
    Last Post: 7th Nov 2008, 15:02
  4. VHS to DVD recorder wont play on computer!
    By topgun68 in forum DVD & Blu-ray Recorders
    Last Post: 3rd Nov 2008, 14:56
  5. Recording a NTSC VHS Tape with a PAL DVD Recorder??
    By Lanno in forum DVD & Blu-ray Recorders
    Last Post: 5th Sep 2007, 03:42
