How do I deal with this. I tried to go with the autopadding and ended up with a file that would not play. I am using VCDEasy.
This usually means your MPEG file is not properly multiplexed. Demux the audio and video streams, and multiplex the streams as VCD or SVCD, depending on what you're making.
I used the standard VCD MPEG-1 in the drop down window in TMPGEnc and re-encoded the file and it worked. The automatic system setting(default) for MPEG-1 would not work. Just some info for anyone having this problem in the future.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
When burning DVD error message about AC3 files keeps coming up
By blueedlilly in forum DVD RippingReplies: 7Last Post: 13th Feb 2008, 11:23 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 12:46 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
Statistics
Newest guides
Latest tool updates
New media comments
