I have reviewed this fourm and the Capture Card List at http://www.dvdrhelp.com/capturecards...&Search=Search. I see very little or no refrence to HDTV capture!
Should I be looking at some other web site to get up to speed on HDTV Video Capture (cards cost $200 - $400) as this forum seems to be for the bottom to middle end of the capture market and I need to look somewhere else for the HDTV high capture end?
There is a software program that will convert the .trp stream to a 1920x1080 MPEG2 file http://www.midwinter.com/~bcooley.
This program converts HDTV MPEG2 tansport stream files to standard MPEG2 video files playable (mostly) by media player, many software DVD player programs, and readable by video converter programs like FlaskMPEG and Vidomi.
ATSC MPEG2 transport stream files are the raw data sent to your Digital television from the broadcaster, and contain multiple mpeg video and audio streams which can be tuned by your digital tuner. These streams differ from standard MPEG2 files in that they encapsulate the standard MPEG2 stream data in small 188 byte packets that are easy to transmit and decode.
HDTVtoMPEG2 simply processes the .TS transport stream files, extracting the data from each of these 188 byte packets, and reconstructing a standard MPEG2 file from them.
I am looking for a "one step" process to convert (decomb etc) this video stream into .M2V and .MP2 or .AC3 files so that I can author with Maestro and make my own DVD-R's. Before you answer this question you need to understand that a little filtering needs to be done on the MPEG2 file.
I see no reference to the following HDTV video capture cards in this forum:
HiPix DTV-200 HDTV
http://www.digitalconnection.com/Pro...ideo/hipix.htm
MyHD MDP-100
http://www.digitalconnection.com/Pro...Video/myhd.asp
HDTV PC Receiver/Recorder Card
http://www.pc-dtv.com/PCDTV-DigitalS...se09-16-02.htm
WinTV-HD
http://www.hauppauge.com/html/products.htm#digital
Here is an excellent guide on
ATSC (HDTV) Video Capture 101 by SmC
http://www.inmatrix.com/articles/atsc.shtml
Thread: ATSC (HDTV) Video Capture
Actually, AVSForum, which is mentioned in the "capture 101 by smc" link you posted is the best site I've seen so far on the discussion of ATSC capture and conversion.
Actually there has been a little talk about the MyHD MDP-100, but not too much yet.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
HDTV ATSC Tuner Quality
By sambat in forum DVB / HDTVReplies: 5Last Post: 24th Nov 2011, 15:57 -
Diamond TV Wonder 650 Theater PCI-E TV Tuner Card ATSC NTSC HDTV FM with Rogers.
By Cabal2000 in forum DVB / HDTVReplies: 3Last Post: 25th Feb 2010, 20:18 -
Can an ATSC tuner in an HDTV read a DVD zone 2?
By julax in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 11:12 -
Are all US tv tuner capture devices going to ATSC models??
By yoda313 in forum CapturingReplies: 6Last Post: 13th Jul 2007, 14:26 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
Statistics
Newest guides
Latest tool updates
New media comments
