New Nerovision Express is out 1.0.4.3b
Hope it's better than the last effort.
Looked like it was going to be a good program but too many problems.
Check it out and let me know how it is.
Thread: Nerovision Express
It is a nice and very easy to use authoring program, also the dvd-mpeg2 plugin is not so bad as the last plugin (svcd-mpeg2). But it takes a lot of time to encode and even if the file is mpeg2 (dvd format) Vision will re-encode it. It has not many options, (extra audio tracks, subtitles..) and no options at all, if you want to capture.
Does it use someone elses render engine or is it their own?
Yes it uses someone elses render engineand you have to purcase this dvd/mpeg2 plugin to be able to create a dvd.
Have a read here: http://www.ahead.de/en/index.html#c1027093248108
ver 1.0.4.3c is out
Is Nero adding templates to new editions or are they improving the writing plug-in?
Their web-site doesn't have revision history anymore.
Improving the writing plug-in? Of course not, the plug-in is the same.
You install it once and works for all Vision updates. It is something like the MP3(pro) plug-in for Nero.
nerovision express
By cyclopops in forum Video ConversionReplies: 7Last Post: 23rd Oct 2004, 20:48 -
new nerovision express
By secretagent in forum Latest Video NewsReplies: 2Last Post: 25th Dec 2003, 19:17 -
NeroVision Express
By MaximumIce in forum Authoring (VCD/SVCD)Replies: 4Last Post: 8th May 2003, 23:46 -
NeroVision Express
By digitalmaster in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2003, 18:18 -
Nero Express Vs NeroVision Express
By enox in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2002, 21:08
Newest guidesLatest tool updatesNew media commentsReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
