i use dvd decryptor dvd 2 avi tmpgenc chapter xtractor and spruce dvd maestro movie is sweet home alabama pls help i have had this problem before but this time i need to fix it pls thanks in advance
Thread: audio sync problem pls help
pls help
need more info..but have you tried ac3 delay corrector?????
just my .02 cents
where is that located i read that someone else used something called that i think how do i use that i am useing the dvd2dvdr for dummies thing right now and it worked before and the sound and pic is great but it is just out of sync, pls help
I don't know if you are doing NTSC or PAL DVDs. If you are doing NTSC DVDs, you probably need to do a "PULLDOWN" on the video.
Anyways, I would suggest that you use DVD2ONE, if you are only interested in the movie and nothing else.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Sony DVD Arch4, audio problem, pls help
By jazu in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2009, 17:14 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
