VideoHelp.com Forum
    I downloaded a movie that is already in .mpg format. Can I use tmpgenc to cut the movie and then burn with nero, or do I have to change any of the settings, or extract the audio, or any thing. According to the info. in movie properties it is a typical NTSCfilm.
  2. Not sure what you want to do here. Do you want to make a VCD or something similar? Then you should read some of the guides on this page!
  3. Banned
    The problem with downloading .mpg is they may contain bad frames and the like, and its not so easy to fix them. Assuming there are no problems with it, and it is a VCD compliant .mpg then yes just split it up and burn it just like any mpeg 1 made with TMPGEnc.
    KingJohns Guide Splitting Mpeg1
    Could I change the properties(bitrate, resolution, etc.) of the MPG in order to make an XVCD, and then use the new MPG for my burn?
  5. Banned
    Then you would need to re-encode it in TMPGEnc
  1. mpg won't stream until the entire thing is downloaded.
    By flycast in forum Video Streaming
    Last Post: 19th Dec 2009, 22:23
  2. Stuttering Downloaded Videos
    By RonLuxton in forum Software Playing
    Last Post: 4th Oct 2008, 14:36
  3. I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
    By emanmb in forum ffmpegX general discussion
    Last Post: 18th Apr 2008, 14:48
  4. downloaded subtitles
    By kidTwist in forum Subtitle
    Last Post: 4th May 2007, 06:20
