In an MPEG file, a sequence header is placed before one or more groups of pictures (GOPs) and contains encoding and displaying parameters. The sequence header can be repeated in order to allow random access, but all the data elements of the repeated sequence header, except those concerning quantisation matrices, must have the same values as in the first sequence header. The repeated sequence header must precede in the bitstream either an I Frame or a P Frame.
To allow for better access and editing, many people place a sequence header after every GOP. In final output, some place fewer sequence headers in (every 5 GOPs, etc.) to save bitrate or make the file smaller.
If you need to add sequence headers to a file you can use the tool MPEG SequenceMaker in the Tools Section.
Results 1 to 1 of 1
Thread: Sequence Header
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
best possible sequence settings
By pjcom in forum EditingReplies: 15Last Post: 26th May 2010, 10:12 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30
