When I try to edit (cut out commercials) on an MPEG2 that I have captured & then reencoded with TMPGEnc, I keep getting "Divided by 0" error after I add the file and click the edit key.
I downloaded the MPEG 2 Plugin and was able to encode the file, but I cannot pull it in to edit out the commercials.
I'm pretty new to this, but I checked a search and did not see this particular problem answered.
BTW, if this helps, I'm also getting weird errors when trying to launch my Real Hollywood Card to replay MPEG 2 files. (Though on reboot this file played fine.)
Thanks!
"I downloaded the MPEG 2 Plugin" which ?
Playback, and to load Mpeg 2 into TMPGEnc
Ligos, LSX MPEG Encoder Suite 2.0
I added the VPAFI MPEG 2 plug in for TMPGEnc available from the Japanese version of their website.
I will download and install your suggestion. Thanks!
Bill S.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 21:02 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45 -
encoding from WMV to .avi usin "decode with QT", audio fails
By fury420 in forum ffmpegX general discussionReplies: 3Last Post: 18th Jun 2007, 00:21
Statistics
Newest guides
Latest tool updates
New media comments
