VideoHelp.com Forum
  1. Hello all,
    What is a good program (prefered free) to used for editing audio so I can put them on my home made movie? things like fading in/out or cut.
    thanks
  2. Member Conquest10's Avatar
    sound forge has a demo. its not that expensive and its a great editor. http://www.sonicfoundry.com/Products...ct.asp?PID=668
  3. soundforge is excellent - but two others you might look into are goldwave and cooledit (none are free, but goldwave is shareware).
    In terms of freeware - you might want to have a look at audacity, which I haven't used, but I think it's quite good.
    have a look around this site for other free audio tools.
    cheers,
    mcdruid.
  4. Member Cornucopia's Avatar
    Digidesign (http://www.digidesign.com) has a downloadable XtraLite version of their famous ProTools software, called ProTools Free. And guess how much it costs?...
    Things to note:
    *Has both PC and MAC versions.
    *PC works only w/ 98,SE, or ME. Sorry, no NT/2k/XP.
    *Mac works only w/ OS9. Not sure about Classic compatibility w/in OSX.
    Requirements are a little stiffer than many other freeware/shareware apps. Probably from its inheritance of functions from its bigger professional brother. 96/128 MB RAM minimum. PC version is alittle picky concerning compatibility with certain CPU/MOBO and Sound Card combos.
    Other negs: A little slow to load up, and works with DualMono files-not Stereo-will make converted copy.I.E. more HD space needed.
    Positives: One of the best, if not THE BEST, editing interfaces. A number of very good FX features, including TimeCompression/Expansion. A VERY HIGH Quality Sample rate converter. 8 tracks of audio (4 if you use stereo tracks), more of MIDI, Most anything automatable and groupable.
    It operates almost identically to its older brothers. And...
    It's FREE!
  1. Replies: 4
    Last Post: 2nd Jul 2011, 11:36
  2. Best audio editing software?
    By Hank Kinsley in forum Audio
    Last Post: 9th Mar 2011, 11:15
  3. Replies: 2
    Last Post: 16th Jul 2010, 21:08
  4. Replies: 8
    Last Post: 11th Dec 2009, 08:45
  5. video and audio editing software
    By limazita in forum Mac
    Last Post: 10th Mar 2009, 07:26
