VideoHelp.com Forum
  1. I have ripped My cousin wedding DVD with OSEx. And I want to make a SVCD, I use the quick settings for SVCD PAL, but when it starts encoding it displays this error:
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    What am i doing wrong???
    thank you very much
    G4 400 Mhz AGP
    80 and 20 GB HDs
    288 MB RAM
    OS X 10.2.3
  2. Do you have the apple quicktime mpeg-2 player component installed?
  3. The apple quicktime mpeg-2 player component is commercial (US$19,99). Do I need it for encoding vob to SVCD?
    Is it mpeg2enc?
    I have installed the 3 components with the "ffmpegX engines installer"
    mpeg2enc, mencoder and mplayer.
    G4 400 Mhz AGP
    80 and 20 GB HDs
    288 MB RAM
    OS X 10.2.3
  4. Originally Posted by macniaco
    It is needed to implement the "qt decode" option that you had activated, and that's the reason you had an error. You can however still encode without this component, either:
    -by using the "mplayer decode" option
    -by disabling both "qt decode" and "mplayer decode" (this will lead to audio sync problems with NTSC material, but will be just fine with PAL)
  5. Originally Posted by major
    I am using mplayer decode option, but it is very very slow (I think). I started this morning at 8:55 and now (20:22) it has still not finished. (For a 99 mins. long movie)
    It shows:
    V: 129.2 100232 97% 922% 0.0% 0 0 0%
    What does mean each number?
    Is the qt decode quicker than mplayer decode?
    If I disable both options will take less time?
    Thank you
    G4 400 Mhz AGP
    80 and 20 GB HDs
    288 MB RAM
    OS X 10.2.3
  1. Installation of ffmpegX on os X.6 : error message
    By Gruntosaure in forum ffmpegX general discussion
    Last Post: 22nd Dec 2010, 18:54
  2. Error on ffmpegX
    By affonsohnunes in forum ffmpegX general discussion
    Last Post: 15th Jan 2010, 08:21
  3. ffmpegx Error Message.
    By Bunky in forum Mac
    Last Post: 25th Oct 2009, 08:38
  4. DIV16B_KEY what does this error mean at ffmpegX
    By joachino in forum ffmpegX bugs and suggestions
    Last Post: 12th Feb 2009, 09:33
  5. FFMPEGX Download POSIX error
    By Miniboon in forum ffmpegX general discussion
    Last Post: 24th Feb 2008, 00:57
