Also known as DV Time, a DV or MiniDV camcorder starts recording at 00:00:00. The timecode is drop frame for NTSC (minute differences in timing are made to get the film from 30 fps to 29.97 fps). DV Time is carried on the FireWire cable with the video, audio and Device Control. The biggest problem that arises with DV Time is that it resets to zero if the camera operator does not 'hook' to the end of the previously shot footage (there is an unrecorded gap between recordings).
If dealing with a miniDV or DVCAM tape with 'broken' timecode (that is in many parts), either do a clone copy to another DV tape so that the timecode is created continuously for the entire tape, or name each timecode section as a different tape.
Results 1 to 1 of 1
Thread: DV Timecode
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 09:24 -
No Timecode on my tape
By towarmforacoat in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 19:49 -
Burned in timecode - HOW?
By synaptic in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2009, 23:41 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00
