A term used in all mpeg video encoders, both software and hardware, which refers to the two 8x8 blocks of numbers appearing under the Quantize Matrix tab in the settings on some encoders or hard coded. These blocks of numbers represent the mathematical functions that the encoder will perform in order to best optimize the video for the appropriate format. Settings vary between a video being encoded as computer animation intended for a computer monitor or full motion video intended for a television. Different Matrix are used for progressive frame and interlaced and also the matrix varies (should) dependent on bit rate.
See also BLOCK and DCT
Results 1 to 1 of 1
Thread: Quantize Matrix
Matrix Character SubRip
By Anonymous171 in forum SubtitleReplies: 0Last Post: 7th Apr 2012, 19:38 -
Avisynth Color Matrix?
By Mdoodm1000 in forum Video ConversionReplies: 8Last Post: 5th Jun 2010, 11:52 -
Custom Matrix file
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 16th Jun 2008, 22:15 -
view quantize matrix?
By J. Baker in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 20:07
