Cinematic film movies are shot at 24 progressive frames per second speed. A Frame is the smallest unit of a 24 fps FILM format. NTSC video is a "field-based" format of 59.94 fields per second. A Field is the smallest unit in interlaced video format. 2 fields make up 1 frame. So, this 59.94 fields per second equals 29.97 frames per second. 1 second in FILM (24 frames) is NOT equal to 1 second in NTSC Video (29.97 frames).
To be able to match the speed of an NTSC Video, conversion from a FILM format to an NTSC Video format undergoes a process called 2:3 pulldown or TELECINE. This process, in simplest terms, means "to add 6 frames so that a 24 fps becomes 30fps which is close to 29.97 fps (another trick is used to get to 29.97). Picture of the process - doom9.org
Results 1 to 1 of 1
Thread: Telecine
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 13:24 -
Weird Telecine pattern
By Island_Dweller in forum Newbie / General discussionsReplies: 15Last Post: 28th Aug 2010, 07:24 -
3:2 Pull-Down and other telecine methods?
By Weef in forum Video ConversionReplies: 1Last Post: 20th Jan 2010, 20:23 -
Removing Telecine Wobble
By robert32 in forum RestorationReplies: 3Last Post: 17th Aug 2009, 06:58 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 21:40
