In an interlaced video a field is 1/2 of a complete picture (Frame) consisting of the even or odd scanlines in the frame. Usually each field is labeled ie. Field A and Field B. When working with interlaced video it is important to note the Field Order (if Field A comes before Field B in the video stream) especially when encoding. If you notice flicker after encoding you will want to change the field order in the encoding template and reencode.
Results 1 to 1 of 1
Thread: Field
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 5th Dec 2007, 23:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 12th Sep 2007, 16:14
