VideoHelp.com Forum
    Hi guys,
    In TMPGEnc ->Enviromental Setting ->CPU - Cache Setting.
    If I check this box (Saves analyzing result of multi pass VBR to cache) would it make 2 pass VBR encoding faster? As the first pass is saved.
  2. The Old One SatStorm's Avatar
    Yes
    Thanks for your reply, but could you tell me the best size cache? Or should I stick with the default of 4096mb. I've got an 80GB partition to play with.
  4. I've been converting home video using 2 pass highest quality with the cache setting at 8192. It normally takes 6-8 hours on my P4 2.4 to convert 35 minutes of video.
    With the cache setting, the total time is 3.5 hours.
    Good Luck.
    I've enabled the cache & set it to 10GB. A film that should have taken 6 hours was complete in 4 hours.
    Two pass high quality VBR. 720mb Divx avi to MPEG2 SVCD.
  1. Replies: 4
    Last Post: 26th Mar 2011, 10:54
  2. TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
    By terpsfan101 in forum Video Conversion
    Last Post: 29th Aug 2010, 07:46
  3. Replies: 19
    Last Post: 29th Jan 2010, 13:47
  4. TMPGEnc 4 Divx Setting
    By Anakin in forum Video Conversion
    Last Post: 14th Oct 2009, 16:21
  5. TMPGEnc DVD Author 3 - Quick Question on a Setting
    By heyjjjaded in forum Authoring (DVD)
    Last Post: 5th May 2008, 16:04
