VideoHelp.com Forum
  1. OK... I have successfully burned a normal video-CD and played it in my standalone DVD player. However - I tried burning a SVCD and continue to get the same warning.,.
    I used TGMPEnc to encode to SVCD format (MPEG).. the file is plenty small to fit onto my 700mb CD. I am attempting to use VCDeasy to burn it. But, when it scans the disk before burning it continually gives me a warning - "Warning - enable scan offets if not done already." What does this mean? Where do I enable the scan offsets? I have looked in VCDEasy, but cannot find it - nor have I found it in TMGPEnc. Help.
  2. No need to worry about it. Most DVD players won't even parse those scan offsets data. You can save some space with no scan offsets. Just burn it .
  3. Member ZippyP.'s Avatar
    Open Vcdeasy, click settings, click (s)vcd player button, in the SVCD section check the box next to "update scan offsets."
    You will still get the warning even if it is enabled.
    The only thing SVCD Scan Offsets does is add an extra 8MB to your filesize.
  5. Member adam's Avatar
    More like 30Mb's, well at the most. Actually some dvd players not only parse the offsets, but they actually cannot maintain sync without them. My old Apex AD600a was like this. SVCDs would be unwatchable without the offsets, but this is pretty rare. Generally the offsets just increase overhead (take up space.)
  1. Replies: 0
    Last Post: 9th Jul 2011, 01:52
  2. Which audio codec I need to enable for playing "cook/ffcook" audi
    By tigerb in forum Newbie / General discussions
    Last Post: 18th Sep 2009, 23:10
  3. PowerDVD v7.3 Ultra: "Fail to enable HDCP" error?
    By ambushed19 in forum Software Playing
    Last Post: 9th Feb 2009, 11:45
  4. Please explain "Progressive Scan DVD menus"
    By schematic2 in forum Authoring (DVD)
    Last Post: 2nd Oct 2008, 19:25
  5. Replies: 2
    Last Post: 31st Jan 2008, 06:35
