I'm trying to usual virtual dub, but when I go to save the wav, it doesn't let me and has this error message:
"Error intializing audio stream decompression.
The requested conversion is not possible.
Check to make sure you have the required codec. (Microsoft Audio Codec)."
Where do I get the microsoft audio codec??
I suspect that the Virtual Dub error is related to VBR audio.
(Variable Bit Rate).
I've had a couple of files with MS audio (hacked codecs as it turned out) and Virtual Dub was unable to process or even play the audio full stop.
I found that NanDub was able to do the required edits though so used that.
If the audio isn't VBR then maybe the audio has been encoded with a hacked MS audio codec...
Virtual Dub may think the needed codec is installed (hence the error) but a hacked version of that codec is required.
If you can load the file in Virtual Dub then use the File menu's File Information panel you'll establish the audio compression and hopefully the required codec.
HTH
Martin.
PS Just go to Microsoft's site and search for 'codec download' and you'll find the codec packages for versions 8 and now 9 of Windows Media available for download.
Trying to Install Microsoft MPEG-4 Video Codec V1, V2, V3
By eon_designs in forum Video ConversionReplies: 2Last Post: 10th May 2010, 13:03 -
Help converting with mkv2vob: Error is Unsupported Audio Codec: VORBIS
By rjsax21 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 22:54 -
Microsoft DV Avi codec - lossy?
By branch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Mar 2008, 23:27 -
Microsoft WST Codec filter & Hauppauge Remote?
By amdk62 in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2007, 11:21
