When I author my SVCD's I add 2 or 3 MPEG stills to the front of my movie.
What is the best way to one fade out as the next is fading in?
I already have Cyberlink Powerdirector Pro 2.1
And also,
what method should I use to have audio on the stills?
Please just direct me to tutorials if they exist.
thanks very much.
The only way to have fades is to just make an mpg program stream. You could use any video editor that supports fades. This would be quite easy to do in Adobe Premiere.
The downside to this is that you will only be able to use 480x480/576 resolution if you want to make a compliant disk.
Its the same way for stills with audio. The only way to be compliant is to just make an mpg program stream and author it as a moving menu as opposed to a still. You can do this very easily with TMPGenc. Load your bmp or jpg as the video source and then load your audio as the audio source. Load the SVCD template and adjust the bitrate, you should be able to get away with a pretty low bitrate, and hit start. It will repeat the single frame for as long as the audio plays. There is one other way but not all dvd players support it. Read this thread to find out how. http://www.vcdhelp.com/forum/viewtopic.php?t=124817
How to Author an SVCD with menus and stills Under GNU/Linux
By khey in forum User guidesReplies: 1Last Post: 24th May 2011, 23:35 -
Best way to add stills to audio
By PrepositionJoe in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 04:53 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 16:28 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05
Statistics
Newest guides
Latest tool updates
New media comments
