i used the installer package from the dmg, and it said installation successful. i use the presets, hi-bitrate ntsc dvd, i change it to 16:9, cause that's what it is. audio, i tried it on ac3, and on pass through, neither has worked, checked the sub box and put in number 1. in options i ony mplayer decode and alvitec checked, then dual cpu selected. tools i have keep elementary streams.
input file info is: /Volumes/Yoshi_s_Paw/MY_SASSY_GIRL/VIDEO_TS/VTS_01_8.VOB
output is :/kiki012603/sassy
i'm really trying to get the mplayer decode to work cause i want to try out this subtitle option.
my terminal output is the following.
Last login: Sun Jan 26 23:20:28 on ttyp1
pbpaste | sh
Welcome to Darwin!
[patrick-tulipanos-Computer:~] superpants% pbpaste | sh
Encoding started on Sun Jan 26 23:20:30 PST 2003
/usr/bin/mplayer -noframedrop -vo yuv4mpeg -ao pcm -waveheader -v -osdlevel 0 /Volumes/Yoshi_s_Paw/MY_SASSY_GIRL/VIDEO_TS/VTS_01_8.VOB -aid 128 -sid 1
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer CVS-030108-15:59-3.1 (C) 2000-2002 Arpad Gereoffy (see DOCS)
Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
Reading config file /Users/superpants/.mplayer/config
Reading /Users/superpants/.mplayer/codecs.conf: can't open '/Users/superpants/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: 44 audio & 112 video codecs
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Volumes/Yoshi_s_Paw/MY_SASSY_GIRL/VIDEO_TS/VTS_01_8.VOB' '-aid' '128' '-sid' '1'
get_path('font/font.desc') -> '/Users/superpants/.mplayer/font/font.desc'
font: can't open file: /Users/superpants/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using usleep() timing
get_path('input.conf') -> '/Users/superpants/.mplayer/input.conf'
Can't open input config file /Users/superpants/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
get_path('VTS_01_8.VOB.conf') -> '/Users/superpants/.mplayer/VTS_01_8.VOB.conf'
Playing /Volumes/Yoshi_s_Paw/MY_SASSY_GIRL/VIDEO_TS/VTS_01_8.VOB
Not an URL!
File size is 719538176 bytes
Checking for YUV4MPEG2
DEMUXER: freeing demuxer at 0x819180
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for MOV
Checking for VIVO
header block 1 size: 0
Checking for REAL
Checking for SMJPEG
DEMUXER: freeing demuxer at 0x8199f0
Checking for PVA
system stream synced at 0x0 (13)!
==> Found video stream: 0
MPEG-PS file format detected.
==> Found audio stream: 137
==> Found audio stream: 128
Searching for sequence header... ==> Found audio stream: 130
OK!
VIDEO: MPEG2 720x480 (aspect 3) 29.97 fps 12000.0 kbps (1500.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
get_path('sub/') -> '/Users/superpants/.mplayer/sub/'
Opening audio decoder: [liba52] AC3 decoding with liba52
dec_audio: Allocating 3840 bytes for input buffer
dec_audio: Allocating 6144 + 65536 = 71680 bytes for output buffer
No accelerated IMDCT transform found
AC3: 2.0 (stereo) 48000 Hz 192.0 kbit/s
A52 flags before a52_frame: 0x2A
A52 flags after a52_frame: 0x2
No accelerated resampler found
AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 24000->192000 (192.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
vo_yuv4mpeg: Using (default) progressive frame mode
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vop scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
libmpeg2: No accelerated IDCT transform found
libmpeg2: No accelerated motion compensation found
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO Config (720x480->854x480,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 720x480 => 854x480 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
VO: Author: Robert Kesterson <robertk@robertk.com>
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
PCM: File: audiodump.wav (WAVE)
PCM: Samplerate: 48000Hz Channels: Stereo Format Signed 16-bit (Little-Endian)
PCM: Info: fastest dumping is achieved with -vc null -vo null
PCM: Info: to write WAVE files use -waveheader (default); for RAW PCM -nowaveheader.
AO: [pcm] 48000Hz 2ch Signed 16-bit (Big-Endian)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
[libaf] Adding filter dummy
[dummy] Was reinitialized, rate=48000Hz, nch = 2, format = 0x00000000 and bps = 2
[libaf] Adding filter format
[format] Changing sample format from 16bit big endian signed int to 16bit little endian signed int
Start playing...
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=29969999:1000000 fps)!!
[libaf] Reallocating memory in module format, old len = 0, new len = 65540
**ERROR: [yuvscaler] No norm specified, cannot determine SVCD output size. Please use the -n option!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
*** [vo] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
/Volumes/ffmpegX0.0.6d/ffmpegX.app//Contents/Resources/mencvcdX: line 202: 637 Broken pipe $command
wait, encoding to mp2 audio with mp2enc...
++ WARN: File length according data tag: 44
++ WARN: File length according RIFF tag: 8
++ WARN: Inconsistency is inevitable if wav's are being piped
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 0 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/kiki012603/sassy.mpa"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
**ERROR: [mplex] Unable to open file /kiki012603/sassy.mpv for reading.
Encoding completed on Sun Jan 26 23:20:31 PST 2003
Results 1 to 1 of 1
pants on, pants off, pants the floor.
No encodes working with ffmpegX
By mollycampbell in forum ffmpegX general discussionReplies: 21Last Post: 1st Mar 2011, 23:27 -
I need help ffmpegx is not working
By jenjen16 in forum ffmpegX general discussionReplies: 3Last Post: 26th Feb 2010, 12:46 -
ffmpegX or no X not working
By movies in forum ffmpegX general discussionReplies: 1Last Post: 20th Nov 2009, 13:28 -
ffmpegX conversion in x264 not working
By trovon in forum ffmpegX general discussionReplies: 1Last Post: 18th Apr 2008, 13:05 -
ffmpegX not working for PSP video
By thuriel in forum ffmpegX general discussionReplies: 2Last Post: 20th May 2007, 08:50
