Ok, I'm backing up my Bourne Identity.. movie alone is like 6.5g. I wanted to keep main menu and couple of xtras.. so I:
1. ripped everything - Decrypter
2. stripped/kept DD & DTS - IFOedit .95
3. re-encoded 2-pass - CCE2.64
4. re-authored - Maestro
The movie now is 4.3g, limiting me now to movie only on DVD-R.. but I want the original working menu with some xtras that I specifically opted for--the menu and these xtras total 1.36g.. Where in CCE do I tell it to leave room for the menu and xtras??
What are my options outside of putting the movie only on the DVD-R, e.g., can I re-encode the 1.36g of menu+xtras?? If so, is it a lot different than doing the movie alone b/c of the different IFO's and all??
why waste your time.
just the burn the movie, rest is all crap anyhow.
-d
You should look at the VOBs containing the menus you want to keep and ascertain their filesize. This filesize should be taken into account when you use a bitrate calculator for the CCE re-encode. You then use IFOUpdate to update the existing IFO files with the new information from your Maestro produced IFOs.
This will effectively 'merge' the existing IFOs and Menus with your new Maestro produce VOBs. There is a guide for this on www.doom9.org.
I have never re-encoded the menus but I'm sure you could do it using the same principle as mentioned above.
Exporting problem and im in a hurry pls help
By HaaL in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 17th Jun 2010, 19:26 -
I know I know its in the sticky but please indulge
By drathnal in forum DVD RippingReplies: 4Last Post: 22nd Oct 2009, 10:17 -
Problem with Samsung DVD-P181 ! Pls help !
By lucianserpescu in forum SubtitleReplies: 1Last Post: 21st Mar 2009, 12:19 -
Problem when encoding...pls help
By Stetsondolly in forum Video ConversionReplies: 11Last Post: 24th Apr 2008, 16:41 -
RMVB to DVD, my umpteenth attempt, jerky video
By silverwolf0 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2007, 04:32
Statistics
Newest guides
Latest tool updates
New media comments
