does a connector exist to that will allow my coaxial cable tv signal from old school tv (with only coax in and out) to plug into my RCA (red, yellow, white) jacks of my Capture card, audio card?
if so, can you find an image of such a connector on the net?
thanx... greatly appreciated...
You can buy RCA connectors at Radio Shack. I make my own RCA/composite cables from cable TV coax.
I think you will have some issues with the tuning though except maybe on channel 3 or 4 unless you are using a tuned signal like from a VCR or TV box.
you need a RF to composite convertor ... you could use a old busted vcr or go to radio shack .
I may be wrong, but I think the coax/rf signal is different from the rca/composite signal. Radio shack used to sell a converter that converts RF to composite. I am assuming you are trying to go from RF to Composite. In some cases. you may have to attenuate the signal or else you may damage your card. Best to ask a TV tech.
Unless you want to buy some hardware to convert your signal (not really worth it), I'd use a VCR or something similar.
Distributing 16 FTA Channels Over one Coaxial Cable
By Girendra in forum Newbie / General discussionsReplies: 14Last Post: 22nd Sep 2011, 09:33 -
coaxial output to cable TV
By kula in forum Newbie / General discussionsReplies: 13Last Post: 22nd Sep 2010, 14:45 -
Hauppauge 350 - Capture with Coaxial / S-Video / RCA ???
By samusaran in forum CapturingReplies: 17Last Post: 30th Jun 2010, 08:58 -
antenna/cable connector broke off back of t.v.
By brenda1906 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2010, 12:42 -
LCD HDTV does not have analog coaxial connector
By phamily06 in forum DVB / HDTVReplies: 17Last Post: 16th Oct 2009, 07:53
