Hi,
I'm trying to convert my holiday movie to DivX in ffmpegX 6.b.
The file is a quicktime export from iMovie, settings: DV-Pal for video and no compression for sound (I've tried other compressions for sound).
The encoding goes well with both mencoder and ffmpeg (both MPEG4 and DivX3).
The result is a DivX without sound.
This normal (as far as I know) but when I use DivX validator 5 I'm not getting a new file (for example X.avi -> X(converted).avi) it just changes the icon and when I double click it Quicktime doesn't even show the video source (nor audio)...
Does anyone have a clue?
BTW: I've succesfully converted the same source to MPEG1 and 2....
Thanking in advance!
Mark
Sub question: Why do I have to put all my DivX's through DivX validator before I get sound?? Even the ones which play perfect on my friend's PC.
I have yet to convert DV to DIVX, but I do have the same problem with the DIVX Validator at times. I think this is because there is a problem with the file, most likely related to the fact that you stated that your file doesn't have sound. Try to put it into DIVX Doctor II, sometimes it states the problem if there is one. The only real advice I can give you is, if all DIVX Validator does is change your icon, then it really hasn't done any kind of conversion at all like it should. Sorry I can't be of more help, but I don't know the answer myself, so if someone out there does, please post an answer.
Wolfwood87
Strangely enough I have to use the 2nd audio channel when converting to Divx and the 1st audio channel when converting to MPEG..
But the result of a DV to Divx is not great.. When the Divx is is deinterlaced the result is slightly beter but audio is still out of sync and motion is far from perfect..
FFmpegX MP4 to DivX/Xvid No Audio
By TDC_01 in forum ffmpegX general discussionReplies: 4Last Post: 21st Nov 2009, 19:49 -
DivX created by ffmpegX doesn't work on player?
By ambrosechapel in forum ffmpegX general discussionReplies: 7Last Post: 17th Oct 2008, 07:13 -
VIDEO_TS to DivX w/ ffmpegx
By motherwell in forum MacReplies: 2Last Post: 7th Apr 2008, 15:10 -
DivX to DVD with FFMpegX - result jerky
By akulier in forum ffmpegX general discussionReplies: 5Last Post: 19th Feb 2008, 16:40 -
ffmpegX 0.0.9 Video_TS to DivX
By stcowboy in forum ffmpegX general discussionReplies: 10Last Post: 29th Dec 2007, 02:11
Statistics
Newest guides
Latest tool updates
New media comments
