I get a lot of MPEG Audio stream errors in the log window. I was wondering what these are and if they could be causing my SVCD's to stutter sometimes when playing back in my DVD Player ?
I am using TEMPGEng to do the encoding from from an AVI file that i captured from my tv ( actually my VCR runnig through my TV). I do not touch the audio section of the TEMPGEnc setup, it is normal SVCD Audio.
Thanks,
Jim
Wouldn't it make sense to post the actual error messages, if you want people to tell you what they are? If there are several, perhaps at least give one or two samples.
The error messages that I am getting are:
"non-MPEG audio stream header seen"
I get 10 - 20 of these per MPEG file ( encoded with TMPGEnc )
I also get a couple of
"mpeg: some marker is not set ..."
I don't think these are causing a lot of problems but I want to know what they mean.
Also is there a file somewhere that explains all of the comments that VCDEasy spits out ?
Jim
It would seem that TMPG is not correctly generating the audio stream. Are you loading the 'svcd' template into TMPG and then leaving it untouched?
If so, it could be that your source is non-standard, and TMPG does not know how to correct it. Certainly by selecting the SVCD template, it should output a compliant stream, but if the input is not good, it may not be able to correct it. I would look to the source for the solution.
Whatever is doing your capture on the PC should have some settings to say 'how' the audio is being stored. I would see if there's a way to capture the audio in a more compliant format in the first place (44.1k). You can also use plug-ins for TMPG to process audio, and/or use a standalone audio processing package (BeSweet comes to mind) to pre-process the audio before giving it to TMPG.
The first step would be to analyse the source audio, then figure out a way to correct it.
YesIt would seem that TMPG is not correctly generating the audio stream. Are you loading the 'svcd' template into TMPG and then leaving it untouched?
I do three types of authoring:
1) DVD rip ( I mean backup )
2) DV through my firewire to SVCD
3) Analog capture to SVCD
I know that the Analog capture has many lost frames and this might be causing a problem. But I also get some of the errors when I rip from DVD and this is a clean, perfect source ( smartriper -> DVD2AVI -> TMPG ).
On another topic; I do have a harder time making SVCD's that playback without skips and lockups when I use source material grabbed from my analog capture card.If so, it could be that your source is non-standard, and TMPG does not know how to correct it. Certainly by selecting the SVCD template, it should output a compliant stream, but if the input is not good, it may not be able to correct it. I would look to the source for the solution.
I assumed that TMPG would eather fix any errors ar tell me about them. What type of errors could get through the encoding process ? And How can I detect / fix them ?
Jim
Scan Audio file for Errors
By MegaTonTerror in forum AudioReplies: 1Last Post: 10th Oct 2009, 09:45 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Batch creation of mpg, mpeg, avis
By silentthread in forum EditingReplies: 2Last Post: 4th Jan 2008, 18:24 -
video audio sync errors
By demonwarrior in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2007, 06:50 -
recycle bin errors
By piano632 in forum ComputerReplies: 11Last Post: 29th May 2007, 09:33
