VideoHelp.com Forum
  1. I've searched and not found any discussion on this.
    I've read that when you re-encode a movie, you need to do the two different pulldowns, put one on the time line for the chapters, and then remove it and put the other on before you import the subtitles.
    But what about a movie that doesn't need to be encoded? I'm making a backup of Unforgiven, and it fits just fine w/o a need to encode it. But the subs are way out of sync.
    Could this have something to do with the audio having a large delay? (2252ms according to smartripper)
  2. Just a followup....I went ahead and did a pulldown on the .m2v file (with the dropped frames, etc), and used it (even tho I didn't need it) to sync the subs. Then I put the original back on the timeline and authored. Everything fine.
  3. Is this a bug in DVD Maestro that need you to swap the movies around for it to work?
    retgards
    Kris
  1. Replies: 3
    Last Post: 7th May 2010, 11:23
  2. Got a really annoying problem, avi sync problem
    By burnleylad in forum Newbie / General discussions
    Last Post: 8th Apr 2010, 10:31
  3. Replies: 1
    Last Post: 11th Nov 2008, 22:16
  4. Replies: 5
    Last Post: 25th Apr 2008, 23:11
  5. DVD Lab message: No subtitle stream normal?
    By stantheman1976 in forum Authoring (DVD)
    Last Post: 21st Feb 2008, 11:10
