i have problems with the mpg's from 24 to convert them to avi. when i do this the audio goes out of sync. ONLY HAPPENS with video's since season 2x02. anybody know what to do (using VDub)
load your avi into virtual dub on the video menu select frame rate then select audio/video duration match,you will probably get a new frame rate for your avi..select direct stream copy and rename your new avi then save. it will only take a minute or so to copy your new avi with the new frame rate.shoul be in sync then...if not i have a program that automatically sync's avi.virtyual dub usually works every time.
i already used VirtualDub in the first place to convert to avi. Tried matchin framerats, helped a bit, but still out of sync for like 0.1 sec
You should be able to use some of the techniques in this guide
http://www.vcdhelp.com/forum/userguides/138106.php
to correct the .1 sec problemPanasonic DMR-ES45VS, keep those discs a burnin'
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
Audio goes progressively out of sync. Calculate the "rate of change"?
By rayden54 in forum AudioReplies: 1Last Post: 26th Sep 2010, 07:48 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX bugs and suggestionsReplies: 2Last Post: 2nd Aug 2009, 17:31
Statistics
Newest guides
Latest tool updates
New media comments
