VideoHelp.com Forum
  1. Man this is a pain in the ass. I did a huge 2.3 gb capture the other day and all worked fine. Used Vidcap, and the morgan mjpeg codec to capture with. 388*352 (some stupid seeting my wintv card uses).
    Anyways when i now try and covert the file to somethin using any program i get the following error message.
    Invalid AVI file: LIST chunk <4 bytes.
    can someone please help cause i cant GRab this again
    1 second away....
    Your AVI seems to be corrupt.
    There's nothing to do about it but recaptering the whole bunch. Be sure you capture in the correct size (352x288 for PAL/SECAM or 352x240 for NTSC), because this is mosttimes the reason that AVI gets corrupt (I've had it with a capture via my DC-10 : 352x576). With me, it was TMPEGenc that corrupted everything !
  3. Make sure you use capture mode (f6) not the compatibility mode(f5) mode. The f5 mode will only work for captures that end up under 2 gb. I have made this mistake many times until I finally found the answer on the virtualDub website.
  4. This is the thing. When i load up something to capture i get the strangest sizes to grab in 384*288,
    Im using a wintv PCI card so if anyone could help that would be great.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  1. Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
    By chindoo in forum Newbie / General discussions
    Last Post: 3rd Jul 2011, 19:51
  2. Avi chunk viewer?- what is this?!
    By vanjo in forum Software Playing
    Last Post: 29th Oct 2010, 02:20
  3. mencoder AVI: invalid audio stream ID: 128 - ignoring (nosound)
    By dialallama in forum Video Conversion
    Last Post: 4th Mar 2009, 08:17
  4. avi chunk viewer
    By agent222 in forum Video Conversion
    Last Post: 15th Nov 2007, 10:03
  5. Junk chunk size calculation
    By maestro777 in forum Programming
    Last Post: 1st Jul 2007, 05:16
