VideoHelp.com Forum
Results 1 to 10 of 10
  1. hi
    complete and utter newbie here, am tryingto burn vcd from mpegs downloaded from kazaa (also avi converted to mpeg with that tn whatever prgram recommended here) but they are only doing about 5 minutes and then saying bad packets...
    can anyone help on this?
    http://www.buffyslay.co.uk
  2. thanks for the tips -
    i have (re)read the guides - and done the check from Virtual Dub, but it comes up as no bad frames...
    crikey!! all i want is to get Buffy season 7 and Angel season 4 on vcd!!!!
  3. Banned
    What is the source ? I bet your using ASF 8)
  4. i have no idea to be honest with you, anyway to tell?
  5. Banned
    Try to load it into Vdub, if it tells you NO then its ASF, other than that in Vdub select file > File information
  6. loads ok
    have now deleted the file though and am re-donwlonading new set of files to try them!!
    so will keep you updated, thanks for all the help so far though..
    xx
    You probably didn't multi-plex the file correctly.
    Try using bbMPEG to re-mulitplex your file.
  9. Banned
    Originally Posted by buffyslay
    loads ok
    xx
    Now we will never know
    XXXX
  1. No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
    By koberulz in forum Newbie / General discussions
    Last Post: 24th Jan 2010, 04:48
  2. mkv to avi shorten duration
    By projecttemp in forum Video Conversion
    Last Post: 15th Apr 2008, 00:39
  3. To Shorten a DVD
    By bryankendall in forum Newbie / General discussions
    Last Post: 1st Jan 2008, 16:00
  4. clip/shorten video
    By fredct in forum ffmpegX general discussion
    Last Post: 17th Oct 2007, 01:13
  5. how to shorten a video
    By legionarios in forum Editing
    Last Post: 16th Aug 2007, 12:55
