How do you determine the VCDEasy default key for your DVD player?
old_Bill
Its usually the play button.
I tried all the keys on the remote, nothing would trigger the action setup for the default key in VCDEasy. Do I need to identify the key in VCDEasy? The actions setup for Previous, Next and Return keys all worked fine. Do all players have a default key?
old_Bill
On DVD players "default" is almost always mapped to Play. This is dependent on the player, it has nothing to do with VCDEasy (unless you've set up the PBC incorrectly). Have you checked the comments on your player in the DVD Players list to see if anybody else said something about the default key?
Thanks to all who replied.
It turns out that apparently APEX did not implement the VCD 2.0 specification correctly in my APEX 3201 player. I found a discussion group at another site where there was numerous correspondance about VCD menu problems with the APEX 3201. To verify that it was my player I played several of the menus on a Samsung DVD player with no problems.old_Bill
Setup default dvd player
By bambam in forum Software PlayingReplies: 14Last Post: 8th Mar 2009, 18:49 -
Does HD-DVD player also rewind/FF to the nearest key frame?
By grasswhopper in forum Authoring (DVD)Replies: 1Last Post: 2nd Oct 2007, 01:13 -
Can I change the default numeric key assignment??
By LisaB in forum VCDEasy GeneralReplies: 0Last Post: 4th Mar 2003, 10:04 -
Power DVD making default player?
By flashbang in forum Software PlayingReplies: 1Last Post: 28th Feb 2003, 16:35 -
How do I reset my loewe dvd-player to default setting?
By vincent73 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Oct 2001, 09:12
