VideoHelp.com Forum
  1. Member LSchafroth's Avatar
    I want to make sure I am doing this right.
    I have XP Pro and a Pinnacle PCTV card. I am using the new WDM drivers from Pinnacle. I can easily capture at 720x576 with no dropped frames at all.
    I want to create SVCD or XSVCD's. I will be using mostly home videos. I will use the RCA ports of the PCTV card from my 8mm Camcorder.
    I will use IuVCR with Huffy and YUY2? Is this right? I have to use IuVCR instead of Virtual Dub since it's WDM drivers. Should I use the enhanced WDM drivers from Iu?
    I'm assuming I shoudl capture at 704x480? footage is 8mm and VHS.
    I then resize it with VD then frameserve for TMPGEnc? Any particular setting to use in VD? Or can TMPGEnc do teh resize?
    I have read plenty of advice for TMPGEnc and none of them are the same, so I'll experiement.
    I just want to have an outline of the steps invloved and software needed.
    Thanks!!
    Lannie
    PC Specs:
    ASUS P3V4X
    PIII650 @ 911Mhz
    256Mb PC150 C2 Ram
    SBLive!
    PCTV PCI
    WD 30Gb 7200RPM
    Looks good.
    I wouldn't use IUVCR's drivers, I've had bad luck.
    Resizing can be 'cleaner' in vdub. That is you can crop first then resize, depending on the scene.
    Remember that Huffyuv takes up a lot of room. Your looking at over 15GB/hour.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  1. Capture device needed ...PLEASE!!!!! HELP!!!
    By Bertomotology in forum Capturing
    Last Post: 4th Dec 2009, 15:29
  2. Replies: 2
    Last Post: 23rd Oct 2009, 07:03
  3. How to confirm the DVD framerate?
    By chiappa in forum Mac
    Last Post: 3rd Jan 2008, 04:59
  4. Replies: 11
    Last Post: 5th Oct 2007, 04:31
  5. Capture and burning advice needed
    By ccm in forum Newbie / General discussions
    Last Post: 30th Aug 2007, 12:25
