All i want to know is..
Im capturing from a VHS source and onto SVCD resolution, my question is as no one likes to drop frames while capturing, whats the lowest frame droppage percentage until the motion starts lagging? is it right off at 1 drops or is it like a minimal of 10 till it starts jerking?
thats all I want to know thank you!![]()
Results 1 to 11 of 11
Thread: Frame Dropping
drop frames while capturing won't make the video lag. the capture program usually sync the video and audio automatically.
So then whats the point of dropping frames???
whats the use if what you stated above doesnt matter?
depends on your computer hardware, the program have to drop some frames (1 or 2) every several minutes to avoid lagging (out of sync between video and audio captured)
but if drop frames that caused by lack of speed on your computer, the program will automatically sync the video and audio (kinda like doubling the previous frame)
If you capture a FILM source in NTSC, every 1 frame out of 5 is repeated, and it isn't very noticeable.
However, if you drop a frame while recording a scrolling text (CNN or Bloomberg TV), you'll see it right away, it depends on the content.
im running:
Pentium-4 2.4Ghrtz 533 Bus Speed
512 DDR Ram
[quote="Dodzzz"]depends on your computer hardware, the program have to drop some frames (1 or 2) every several minutes to avoid lagging (out of sync between video and audio captured)
[\quote]
depends on the program
VD does that, but Virtual VCR doesnt drop any frames for sync purposes, it uses resampling techniques
Try Vitrual VCR and see if you get the same dropped frame rateAMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb
Virtual VCR?
is that a new capturing program? if sdo is it on this site? thnxs
http://www.digtv.ws/
enjoy
Thanks, im pretty much going to capture off my Direct Tv Receiver and my VCR. would you recommend using this program for both or VDub for certain things? thnxs
depends on your OS
as they says,
AVI_IO for Win98
Virtual VCR for Win2k/XP
and i would agree on the later but jave never captured with Win98 mysef
hope this helps
PS use VD for all your editing
Edit: added last lineAMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 04:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum CapturingReplies: 5Last Post: 13th May 2010, 09:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 06:55 -
Dropping frame with profile H.264
By n69 in forum Video StreamingReplies: 2Last Post: 22nd Dec 2008, 21:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 02:41
