Someone please help. I'm going nuts with this. Just bought a new cd-rw from Micro advantage 52x24x52x. My computor reconizes it but VCD Easy willnot. ASPI up todate. Didn't have a prombem with the old LG. Running windows 2000. PIII 866 512 ram. Maybe i'm missin somthing? Please help.
Thread: Help with VCD EASY
In VCDEasy, in the bottom right corner, does it say ASPI seems valid: yes, or ASPI seems valid: no? If it says ASPI seems valid: no, that is your main problem. In that case I suggest you go to: http://www.afterdawn.com/software/cd...ls/frcaspi.cfm , download the ForceASPI drivers, install them and reboot. If after you reboot, it shows "ASPI seems valid: yes" then on the CDRDAO settings page, select generic-mmc as the force driver for the CD Writer, select your specific CD Writer in the dropdown menu for that section and check the force execution box. Now you should be able to burn using CDRDAO, which is the CD burning program built in to VCDEasy.
Mpeg movie cut in half when using VCD Easy to make VCD.
By caseychu in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2003, 21:04 -
Easy question about klh kd 1220 (easy easy easy)
By dinkob in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jul 2003, 00:20 -
Procoder VCD MPEG1 files not recognized in VCD Easy??
By xnofriendsx in forum VCDEasy GeneralReplies: 0Last Post: 13th Dec 2002, 14:41 -
playback file not complete using VCD Easy to create VCD.
By kennethparker in forum VCDEasy GeneralReplies: 1Last Post: 5th Nov 2002, 19:49 -
VCD Easy - not so easy?
By sterankin in forum Video ConversionReplies: 7Last Post: 23rd Apr 2002, 18:25
Statistics
Newest guides
Latest tool updates
New media comments
