I had some minor problems with MC Encoder 1.3. The encoded mpg files would not play properly in Windows Media Player 9.0 or Elecard mpeg player. I emailed MC regarding the problem and they confirmed my findings.
Do not go from DirectX 8.1 to DirectX 9.0, if you are using MC 1.3 Encoder. You may have problems. MC assured me the new version will be DirectX 9.0 compatible. I was able to get Elecard to play by hitting the end of video button and then go back to the beginning by hittng the appropriate button. My DVD player could also be fudged to work.
Here is a copy of MC's reply to my email. I prefer the word will to should, let's hope they mean the same thing, in this case.
Hello,
We do have problems with directX 9. We are working on a solution. The
next version of the encoder should work with DX9.
Regards,
Patrick Kuckertz
Results 1 to 1 of 1
Thread: Main Concept & DirectX 9.0
First Impressions: ADVC-100 & Main Concept 1.4 MPEG Enco
By Will Hay in forum CapturingReplies: 33Last Post: 20th Feb 2004, 16:25 -
main concept help
By mickmason247 in forum Video ConversionReplies: 1Last Post: 30th Jul 2003, 12:52 -
Main Concept
By Gurm in forum Video ConversionReplies: 11Last Post: 29th Jun 2003, 08:02 -
Main Concept
By alexasha in forum Video ConversionReplies: 0Last Post: 12th Jun 2003, 17:32 -
By pepegot1 in forum Video ConversionReplies: 0Last Post: 2nd Jan 2003, 20:07
